1 - 9 of 9 Posts
There was a "pop" type noise at 9 seconds. What was that? Did you drop your recording device?
As for the knocking noise, what kind of oil are you using? If the oil is too thick, the engine won't like it and be a possible cause of the knocking noise.
When did this start happening? If recently, what were you doing where you first noticed this noise?
There are all sorts of things that can cause the engine to knock. It could have been caused from insufficient oil (not enough oil added at the last oil change, car is leaking oil, oil pump is failing, or any combination of these), bad gas, carbon deposits in the cylinder(s) or combustion chamber, you're using non-approved spark plugs (they need to be either Denso or NGK Iridium).
Worst case scenario is that you have a bent piston rod and the entire engine will need to come out to fix it. If that's the case though, you might as well just redo anything else that needs replacing such as gaskets and give it new rings as well.
not as far as i know. but i'm only familiar with the v6 and we're not sure what you have since you haven't stated what you have. you've only stated the mileage of your car.
1 - 9 of 9 Posts
