No, you just wired the relays incorrectly. A bad relay doesn't engage; it should never induce a short circuit and blow a fuse.hids are now working i stopped using the relay and they now work. so i'm guessing it was a bad relay. has anyone had any problems running 35w hids without the relay?
+1.no, you just wired the relays incorrectly. A bad relay doesn't engage; it should never induce a short circuit and blow a fuse.
