1 - 4 of 4 Posts
X-Gear
Also available in sober.
Aftermarket wheels are neither good or bad for your car. 15s are gonna look pretty small though.
The biggest issue you might run into with aftermarket rims is there effect on horsepower (@ the wheels) and fuel economy. Many of the aftermarket rims are heavier than the stock rims, but if you are trading 15” rim for another 15” rim there will not be much difference in weight so there will not be much difference in HP or MPG. I personally think you should stick to the stock rims unless you are going with a larger rim (17” at least), but that is just my opinion.
X-Gear
Discussion Starter #4
are the MB Wheels drifter good?
has anyone used them?
1 - 4 of 4 Posts
