1 - 5 of 5 Posts
I think that's alil too aggressive of a set up. Your wheels will stick out alil unless you run a super high negative camber.
If you must have this set up then 225/35/20 on the front and 265/30/20 on the rear will work but the rear is gonna be alil stretched.
I'm running a 245/35/20 in front and 275/35/20 in back.. But u will def have to roll your fenders
all depends on how low you are, but you'll definitely need to roll the fenders and see how it looks...
1 - 5 of 5 Posts
