This sounds like one of two possibilities.Hey all! 09 Accord 2.4 & the 1st plug on the pass. side spins, but won't come out. Any wisdom is deeply appreciated! Thank you in advance!
Wow, it does sound likes its cross threaded and stripped , I mean if you know for sure your socket is snug fit over the spark plug than that’s mostly what it is. If that is the case than most likely the head need to come off to be repaired. Good luckHey all! 09 Accord 2.4 & the 1st plug on the pass. side spins, but won't come out. Any wisdom is deeply appreciated! Thank you in advance!
