1 - 8 of 8 Posts
Hello all. Attempted to change the tranny fluid in my 2000 accord 4cyl yesterday.
In doing so, I managed to almost strip the 3/8" head drain plug. I lodged a 3/8" racket into the plug and heated the surrounding area slightly with propane. Gave it a few good pulls and the racket began to slip, slightly rounding the inside if the plug. Anyone have any suggestions, or tips for getting these out?
THanks
If it is the part of the plug that you insert your ratchet into, and not the threads of the plug, then yes....
A muffler shop may charge you $25 to simply weld a piece of metal onto the plug, then you simply use that to unscrew the plug. Buy a new OEM plug for follow up....
If the 3/8 square drive is ruined, the drain plug has a large area you could use a pair of vise grips on.
↑ ↑ ↓ ↓ ← → ← → B A
You can try wrapping the drive of the socket wrench in PTFE tape to give it a nice snug fit with the drain bolt and try to break it loose. Also, make sure you're turning it the right, or should I say left (i.e. counter clockwise), way.
Thanks for the replies. The threads are good. I couldn't get the plug to budge. Just elongated the inside of the head. I think I may be able to get vise grips on it. Maybe that in conjuction with taping the racket and pulling at the same time will work.
<= Jeep differential LOL.
Ratchet. More accurately: socket wrench.
I would use an impact wrench to begin with. They work like a charm on seized threads.
Can't really advise now after damage was done.
Bout it, Bout it
When I went to do the first drain & fill on my rebuilt tranny, the drain plug head was already totally stripped and rounded out. Stupid tranny rebuild shop.
I was too lazy to try different ways to get it out so I paid my indy $30. Since the car was already on the lift he changed out the fluid as well with DW-1 I provided.
1 - 8 of 8 Posts
