If you know the 7th gen Accords then you'll enjoy this rabbit hole I'm going down!
2006 Honda Accord 4cyl 2.4L LX-SE. 190k miles, this is my girlfriends car, runs great. It's taking about 2.5 seconds of key cranking before the Accord turns over and starts. If it's a cold morning and the car has been sitting all night, it can take almost 3.5 seconds of cranking before turning over. A few times this weekend it would die during cranking, but I'm unsure if she just didn't hold the key long enough or what happened. I witnessed it die during cranking twice this weekend, and internal lights remained on but cranking did die. Presumably not battery, presumably alternator or starter or fuel/air flow? Let the rabbit hole commence:
1) Air filter dirty, replaced.
2) Air intake hose is dry rotted (I cracked it upon getting to the airfilter), replaced air intake hose. (noticed throttle body has black carbon buildup along the disc edge)
3) O'Reilly's did free battery/alternator/whatever test, all passed with flying colors.
4) O'Reilly's salesman made a case for using an $8 bottle of some sort of Lucas Oil fuel additive, recommended against seafoam so I don't eat away everything inside. Figured why not. I've always thought this stuff was snake oil, but what do I know. Drove until tank was almost completely empty, pulled up to gas station, poured in the additive, then filled up the gas tank.
First crank after additive was added, was failed - not sure if gf just didn't hold key the whole time or what. She tried again but this time while pressing the gas pedal slightly, still no luck. I got in and cranked while pressing the gas pedal down hard, Accord turned over successfully. I drove for 30 min at highway speeds. Hasn't died since, but still taking a long crank until turning over.
Just based off all this, what do you think is the likely cause of this slow start?
I spent hours on this forum and on YouTube. Here's what I've tried/evaluated:
1) Key Cycle Test to prime the fuel pump: still long crank until turn over.
2) Aftermarket electronic drawing power, so I removed some aftermarket broken bluetooth device: still long crank until turn over.
3) Spark Plugs: not likely because I'm not having any misfires and the tachometer is completely stable. Is there an easy way to test them and rule them out?
4) Ignition Switch: not likely because not hearing buzzing from fuse box and not having stalls on road.
5) Battery: only 1 year old, tested at O'Reilly's.
6) Battery Cables + Ground: not likely, all connections tight, no corrosion, no bulging cord.
7) Starter Motor: not sure, because it's never not cranked. I've read here that it's recommended to bang on the starter motor, have yet to do that.
8) Throttle Body: I'll clean it this weekend. But if this was the culprit, wouldn't I have issues with acceleration and low/high idling?
This car has spent much of it's life in the temperate midwest. However, there were 2 years spent in HOT New Mexico. It's been back in the midwest for the last 2 years now.
Could the starter motor have gotten damaged from heat, making it still crank but just slow to turn over?
What are some telltale signs of spark plugs needing replacement?
Fuel Pump...does the priming test not work on Accords? Is there another way to check the fuel system?
