1 - 6 of 6 Posts
Hi,
I got a pair of Jack Stands. I wanted to change brake pads, change engine oil and flush power steering fluid flush this weekend.
For brakes I used the scissor jack to lift a side at a time and changed pads.
But for changing oil I need to get under the car so will have to use stands. There is no way I can lift the car using scissor jack and have jack stand next to it as the 4 lift points on the side of my 07 Accord Sedan aren't that long/wide.
Should I lift the rear end of car using scissor jack to place jack stand on the front ?
Please suggest.
Accord Power
I think you need to buy a bigger Jack than the spare tire scissor jack. The Scissor jack is only meant to allow you to change flat tires. A bigger shop or equivalent of jack, can be positioned under a solid frame of the car to be lifted up enough so that you can get jack stands underneath.
No matter what, you should jack up two sides at a time. The job will go easier that way.
http://www.sears.com/shc/s/search_10153_12605?keyword=jack&x=0&y=0&vName=&viewType=gal&viewItems=24
Something like those can help you alot. If you want something bigger, you can get a shop jack.
I hope that helps some. But diffinalty use something other than the scissor jack.
Accord Power
Ah, won't the ramps prevent you from getting to the brakes? While the ramps are useful, you'll still need a better jack than the spire tire jack.
Details, details........
But of course you are right!:thmsup:
Discussion Starter #6
That is true, but I had done brakes before I started with oil change, and hopefully wont be needing a brake change for another 30k miles or so (I drive about 7-8k miles annually :)). Ramp would be easier to oil change and other routine stuff, especially in winters since I leave in a rented apartment (no garage).
Next week would be changing rear window regulator, looking for a DIY if there's one.
Thanks.
1 - 6 of 6 Posts
