1 - 9 of 9 Posts
i'm not too sure about how sizing works, but i'm looking at a set of rims from a hyundai genesis coupe with the following specs:
Bolt Pattern: 5 x 114.3
Front
Wheel Size: 18" x 7.5"
Wheel Offset: +35
Rear:
Wheel Size: 18" x 8"
Wheel Offset: +35
Tire Information
Brand: Bridgestone Potenza RE-92A 91V UTOG 260 A A
Size
Front: 225/45/VR-18
Rear: 245/45/VR-18
will these fit on my 7th gen? (03 V6 w/ stock suspension)
i will be searching as well, but this deal isn't gonna last so the quicker i can find or get an answer the better.. thx in advance guys :)
Also available in sober.
Anytime you are pulling a wheel of of another car, you are going to want to physically test fit them on yours to make sure they do or do not fit.
NHBP AV6 6SPD coupe
might need hub centric rings if holes are bigger. if they are smaller then you pretty much out of luck unless you run spacers
your front wheel will stick out almost an inch (23mm) inner side only gona go in 3mm
rear inner clearance from rim to strut gona be 9mm less then stock and will stick out 29mm. little more then an inch
if it fits it will look pretty good, more flush then it is now
http://www.1010tires.com/wheeloffsetcalculator.asp
The rear wheel is pretty large and may rub but it has a good offset so not sure on that. You'll want to be sure the center bore is correct. Eg; Nissan wheels will usually fit on a Honda due to larger center bore, but not the other way around. I wouldn't buy without actually test mounting.
Should fit, only thing to worry about is the hub size...
sorry to jack, but what do you guys think of 18x9.5 all the way around with a +38. how will this look as far as sticking out, and will it clear rl caliper.
Dont put staggered rims on an accord its front wheel drive,,,,, im not gonna boss saying you should leave them but thats just not right, the belong on a rear wheel drive sorry
didn't want to make a new thread cuz i was wondering the same thing. can someone answer this? instead i want to run +15 all around. Can 18x9.5 +15 fit on a 06 coupe lowered about 1 finger gap without any modification to the fenders? thanks in advance
1 - 9 of 9 Posts
