My Honda Accord 2005 2.4L has a crank-no start problem. These are steps I have done on it.
1) tested spark and found none.
2) Fuel was OK, I heard fuel pump running and smelled gas when starting engine.
3)Replaced Crankshaft sensor.
4)Replaced ignition switch assembly dued to key issue
5)No key immobilizer issue.
6)No warning lights on dash board.
7) Scan engine and found no error codes.
Below is the descbription of the problem (I strongly believe so), with the key turned on I found
1) The ignition relay , R1, had 12 VDC at one end ( terminal 4, coil side) and also 12VDC at terminal 3, this implied that there was no path to ground. I also took R1 and bench tested it, it's fine. Terminal 3 is connected to PCM , terminal E7.
2) I removed R1, started engine, same problem, crank no-start
3) I did try to reset the PCM by it by disconnecting battery negative and removed F2,F4 and F7 which are engine management fuses and backup fuse.
History of car:
Like many of old Honda Accord cars, it had starting issues due to ignition switch. Sometimes it would buzz but won't start, key and key socket very worn out, one day it locked the steering wheel so I decided to replace it.
Due to Covid-19 my son was out of work for a few months. One day he had a job interview and the car did not run.
Questions:
1) Assumed that the PCM is the problem, why every thing else work and no light on dash board, no error codes.
2) There is open connection from the R1 to PCM. This is very unlikely to happen because no fuse burned.
3) Is there a way to test PCM without removing it from a car?
History of car:
Questions:
