My 2006 Honda Accord (VP) 4 Cyl. High beam is on ALL time even when the engine is off.
My accord is all stock equipped.
When it first happened I had to unplug the battery to save it.
the following night I looked all over the fuses inside the cabin and under the hood and they look OK.
I checked the lever and it's looks OK :
-small light and head light/low beam turn on and off with no problems.
-high beam (blue) in dash indicator works ok in both high beam position (push) or flash(pull)
-when low beam is off and I pull the lever to flash I get the blue indicator and low beam works while the high beam is on constantly.
all that means to me that the problem is NOT from the control lever, it is somewhere in between
Now the high beam bulbs are unplugged till I can find a solution.
Any one knows what's going on?
