1 - 9 of 9 Posts
2012 Honda Accord EX Coup
I bought my first 2012 Honda accord coupe ex for my wife. It has a little over 43000 miles on it. Oil has been changed on a regular basis with paperwork. it was changed with maxlife 0w20
I plan to keep using maxlife 0w20
now the question: at what mileage do i change the transmission oil? Does the 2012 accord with 4 cyl have the filter that requires changing? i cant find anything on the issue in the manuals.
thanks for your time
Stan
2015 Accord Touring I4
The 2012 has a maintenance minder system that will tell you went to change your transmission fluid. Typically Honda suggested at 96,000kms, then 48,000kms there after... so i did mine every 48 from new.
That would convert to doing it every 30k miles.... honda trannies need to be taken care of well.
There is a non-serviceable filter in the tranny, I never owned an auto 8th gen so I will let someone else chime in for you.
Stan the Man:
Our Canadian friend speaks the truth....
Change your auto transmission fluid with Honda DW-1....do it now, as it is time. You can do 1 drain and fill procedure (3 quarts of fluid) and it will take you about ten minutes AFTER you remove the lower plastic shield.
As for the filter, do a search because you have an external, $20 filter. Your Generation Accord and mine have pretty much the same engines. It takes me about 10 minutes to replace mine...all you will need is a 10mm socket, a 9 inch extension, a ratchet, and 90 degree bent pliers- preferably 9 inch as well. I do mine every 3 years....Honda does not list this external filter as "serviceable". But as 08EX-L stated, take care of your tranny.
Search for transmission filter replacement for 4 cylinder Accord, 7th Gen. Procedure is same.
1) Really stick with DW-1 on this....don't go aftermarket. Honda transmissions are kinda picky about this.
2) Update your user CP to include your location- lots of maintenance questions depend on location....that helps you and the next guy who comes across this thread.
Good luck.
Discussion Starter #4
thanks for the reply 08. I'm still new to the maint minder. I located the oil life but not the trans life. i'll keep reading
Discussion Starter #5
Rick,
I always stick to Honda fluids on my bikes and ATV. I will continue to use Honda dw-1 atf in the accord.. as far as engine oil I'm a Valvoline maxlife guy. P1 filter (thinking about changing this due to some failures on BTOG website)
thanks for the info.
Stan
Anyone have a part # on the 8th gen trans filters? Is it the same one across 08-12 accords?
want to see if Honda stocks them and not much money.
Car so nice, bought twice
See RickBlaine's post above for the link to the part and how much it costs from Honda. $20 a pop...probably overpriced by about $13 since a Wix fuel filter that looks VERY similar costs $7.
1 - 9 of 9 Posts
