1 - 10 of 10 Posts
Hi All,
2003 Accord V6 Sedan
Anyone out there replaced their hood? Anyone out there know how to do it effectively?
The nose of mine (underneath one of those 3m protectors no-less) has a ton of rust building up -- like all the way through. I'm just going to salvage one hopefully and replace it. Can't complain too much, the car has 235k on it. Surprisingly the rest of the body looks great, just where the 3m film was lol.
3rd Gear Roll
i dont remember ecatly what the hinge system is like, but your best bet is to probably detatch the hinge from the frame and pull it off. you might want an extra set of hands just in case... then pull the hinges off the old hood, and re-install on the new one, then just bolt it back onto the car.
shouldnt be much harde than that. i think youll need a 10mm or 12 mm socket and wrench, you should be covered with 10,11,12, and 13mm
Thanks guys -- yeah I haven't even looked at it. I'm guessing the tougher part will be finding a 'new' hood.
Should just be a few bolts at the hinges. I'm guessing the air struts will need to be reconnected as well. 2nd person, maybe even three is a great idea since it's pretty bulky.
I'm guessing there's some wires etc embedded in the hood under the insulation.
03 EX V6, and 6 others
Two bolts on each hinge (10mm). Then pop off the supports on each side.
Takes about 10 minutes tops to remove. I pulled mine off last year to paint it, then again last weekend to pull the engine.
Hi All,
yea, mine is looking the same way but does not sound as bad as yours. Salvage yard is out of the question as most likely the same issue. Maybe a carbon fiber hood?
'04 Accord EX, 5AT
Check out rockauto, i seen it there for good price. Just make sure to get CAPA certified ones and youre good. Youll need paint of course.
Shipping at Rock is as much as the hood. I'd try some other sources. I actually am talking to a local plastidip/window tint guy who can get OEM/CAPA for ~$140. Also try a PDR guy--them may have a source.
1 - 10 of 10 Posts
