1 - 4 of 4 Posts
make sure you put the plastic slots in all correct spots. use the picture as a reference. those things can be tricky
Hmm... Make sure the clips are sitting flush and does not stick up. Or you could take the clips out again, give them a clean if they are dirty. Mine were a bit dirty and didn't fit in properly, so I washed them and they fit like new.
**Make sure that the handle/lever is on top of the plastic trim... and not under it. The lever must be "threaded" through the hole.
If it still doesn't work, try slamming the hood down a bit harder than usual. Good luck. :D
Make sure the front lip of that plastic piece slides UNDER the top of the front grille mylar / faux-chrome. I made that mistake a while ago...you have to install the piece with the front pointing at a downwards angle. Also check to make sure the 2 rubber things closest to the latch are screwed down all the way (turn clockwise).
I would also help if you would take a pic of your car so we can see if something is off. I'm assuming the pic you provided is from someone else's tutorial.
1 - 4 of 4 Posts
