I will test drive one tomorrow, just want to get some heads up. Thanks.
Or when changing lanes, as another vehicle can from two lanes over can move into the lane you intend to change into at the same time, and you cannot see that without a quick shoulder check even with the best mirror adjustment, two cars occupying the same space at the same time will be unpleasant!But once you get comfortable with it, you'll never feel the need to turn your head around while doing 60mph ever again.
**This technique is while moving forward only. It does not replace looking over your shoulder when backing up.
Will try it out.Learn to adjust your mirrors and you won't have a blind spot. I've used this technique in every car I've driven since finding this info several years ago, and it's never failed once--SUVs, vans, hatchbacks, trucks...'08 Coupe included.
I don't recommend doing this for the first time as part of your test drive, as this technique takes about 2 weeks to get used to and truly "trust". But once you get comfortable with it, you'll never feel the need to turn your head around while doing 60mph ever again.
I realize this might not help you out for your test drive tomorrow. Either way, I can't comment on a "blind spot"...as I don't have one.
i do want to use this technique for my car, but the only problem is that i use my sideview mirrors for when i back out of alleys and tight driveways without accidentally scratchin the side of my car on the wall. is there any technique for achievin this with the use of this mirror technique?Learn to adjust your mirrors and you won't have a blind spot. I've used this technique in every car I've driven since finding this info several years ago, and it's never failed once--SUVs, vans, hatchbacks, trucks...'08 Coupe included.
for my car, i usually just adjust the mirror where i can barely see the door handles. whenever i back out tight driveways, i just take a closer look in the mirror before i move to make sure i am clear without having to readjust the mirror. if i dont feel comfortable backing out, then i would take a good look around the tight driveway or alley and just have a plan of attack or have a trustworthy person stand outside and guide you out if possible. try folding in one mirror and using the other to see the side of the car.i do want to use this technique for my car, but the only problem is that i use my sideview mirrors for when i back out of alleys and tight driveways without accidentally scratchin the side of my car on the wall. is there any technique for achievin this with the use of this mirror technique?
i fully agree with this statement because i have actually sat in the new accord and imagined changing lanes on a highway from the driver's seat. i thought that the view from the left rear window was very low, but i figure once you can adjust the seat just a little further back it does help to some extent, but the key is getting your mirrors to capture most of what you see on the side.I really hate the size of the headrests on the new 08 Accord sedan (haven't driven a coupe) because it is difficult to see out the rear left window. I found that the Altima is the same as well. I may try getting my mom's 99 headrests and putting them in my sister's 08 to see if makes a difference, I'm betting it will. Car manufactures just don't give you the clearance to see in the back side as they used to.
