So, I have a 2012 I4 ex-l sedan and have noticed I drain 3.5 qts of engine oil and refill 3.5 qts. Dipstick always reads at the top hole / mark of the dipstick. I also know what I'm doing but just wondering if the dip stick could be incorrect.
Filter was changed -Better change the filter too
yes - drained hot. I am going to recheck a few things - like the hot vs cold fluid level differences. so 4.2 qt and I have an actual volume replaced at 3.8 qt, (not 3.5 as stated above) after rechecking container.I didn't change my filter and it was a bit under 4qts drained which is right at spec.
Were you draining with the engine hot?
