1 - 1 of 9 Posts
There isn't a whole lot you can do to adjust your clutch. Your engagement point is going to be pretty much be whatever it is. You should be able to look at your clutch pedal and see where you adjust it. The following from the service manual provides the specifications for what can be adjusted. Good luck.
Loosen the clutch pushrod locknut, and turn the
pushrod in or out to get the specified height,
stroke, free play, and disengagement height
at the clutch pedal.
Clutch Pedal Stroke: 130-140 mm (5.12-5.51 in.)
Clutch Pedal Free Play: 10-18 mm (0.39-0.71 in.)
Clutch Pedal Height: 191 mm (7.52 in.)
Clutch Pedal Disengagement Height:95 mm (3.74 in.)
1 - 1 of 9 Posts
