1 - 4 of 4 Posts
So, my map lights haven't worked since I bought my car, and I finally decided to go with led interior lights and can not for the life of me figure out how to get to the bulbs. Anyone changed these and can give me a little info? Thank
Turn the map light switch OFF.
Carefully pry the lens (A) off with a flat-tip screwdriver.
Front Individual Map Light: 8 W x 2
Install the light in the reverse order of removal.
I slide a credit card into the crevice and pop the lens.
Sweet, thanks! I was thinking of prying with a screwdriver but afraid is break something haha. The credit card did perfect. Thanks again!
The best thing to use is plastic trim remover, screwdriver is too harsh on plastic.
Here is the link to remove the lens, but I suggest you to pry the one near the center first because it's clip on, the other clip nears the passenger or driver has a curve back end like a hook.
So you should pry the one near the center, then push the len towards the center.
1 - 4 of 4 Posts
