21 - 40 of 320 Posts
Yeah thought there might be a touch screen approach similar to the non touch screen approach that's in the video maybe not but can't imagine they would provision for one and not the other. Was hoping to test it this way before clipping the wire to hear the difference first. Oh well.
There is, someone will leak it or discover it..just a matter of time.
I don't believe the only way is to cut a wire in the rear head liner...Has to be another more convenient place to unhook or cut a wire, until, we get a code (button sequence) to disable it-->:dunno:
I'm still messing with the makeup on my ride, when I move to the sound system, I hope for a better solution to tearing out the head liner.
It is the front mic where you cut a wire. Not a big deal to do. It is the rear mic, above the headliner, where you simply undo a connection. Very easy to do, no one said you have to tear out the headliner.
OK..I'm exaggerating,, But I thought I read a report of damage to the headliner after unhooking the rear-->:dunno:
My point is, in time there will be a very easy way avaiable to us, (no matter if Honda wants us to know it or not) to disable & enable ANC.
why would you want to disable it? what does it give you???
Search this thread and the forum. Supposedly it improves audio quality which also out weighs any noise cancellation that might be gained. That's what we want to test before potentially cutting any wires to do so permanently.
Retired from Car Biz....
It's an enthusiast thing....Honda designed a system for the average family man that makes the car quieter. But enthusiast don't like that and want the stereo system to be a shade better. So be it. Disconnect away.
I don't care. The stereo sounds great to me (and yes I like to crank it) and I like the noise cancellation of the engine.
So to each his own. But I understand why Honda did it....and will leave it alone.
Honda fan
And the video which shows how to in a sport. Would like to know how to do this with a touch screen with/without navi.
start vehicle, press and hold display+back+power
Reactions: kltk1
is engine noise much louder with ANC off ?
When I test drove an LX, it was already pretty loud under regular throttle.
it a quite car already. Turning ANC off didn't make the car louder to me. with that said, not that the radio sounds better it might be turned up a notch or two more :)
How to disable the ANC/ASC (active noise cancellation) on the 2013 Honda Accord.
All,
I am new on DA and have learned a lot so far by reading what others have posted. I am giving back with information that I think was lacking.
I have read several posts about folks disabling the microphones in their vehicles to defeat the ANC system. I'm hesitant to do this and sought another solution. By the way, I don't even have my vehicle yet, my 6MT sport is scheduled to be built later this month, so I can't try this out just yet.
I paid to have my question answered by a Honda Master Technician on justanswer.com (I am not affiliated with this website in any way).
I will tell you that it is possible to disable ANC without cutting wires. There should be 4 attachments to this post with diagrams.
If you have a short attention span, you can skip to the end.
Here is an excerpt from the 2013 Honda Accord Press Kit, describing the system:
Active Noise Control (ANC) and Active Sound Control (ASC)
Key contributors to the Accord’s quiet, refined interior are Active Noise Control (ANC) and Active Sound Control (ASC). The two systems are comprised of dual overhead microphones, an ANC/ASC electronic processor, and the audio system’s four door-mounted speakers. ASC/ANC operates whenever the Accord is running, even if the audio system is turned off.
ANC is designed to reduce low frequency sound in the cabin caused mainly by the roughness of the road surface. The overhead microphones pick up sound waves and send them to the ANC/ASC processor, which creates and sends a precisely timed "reverse phase" audio signal to a special amplifier. In turn, the amplifier drives the door speakers to cancel the original noise signal.
ASC is a related technology designed to improve the engine sound quality by making the sound pressure level more linear as the engine revs increase. Typically, engine noise doesn’t increase in a linear way with rising revs; instead there can be many resonances that create peaks and valleys in the sound pressure level and an uneven sound. ASC helps smooth out the engine sound by creating a same-phase or reverse-phase sound signal as needed and sending it to the door speakers. Though the system offers benefits from idle to redline, it makes the largest difference in the range between 1000 and 2000 rpm, where it lowers the sound pressure level by approximately 3-dB with an opposite-phase audio signal.
The following is my posted question and conversation with the tech:
Question:
I would like to add an amplifier and subwoofer to a 2013 Honda Accord sport sedan, while keeping the factory head unit. I'm told that I will experience a low hum when the Active Noise Cancellation (ANC) kicks in.
Is there simply a wire going to the factory head unit that can be cut, or is there some other way to defeat ANC? Thanks!
Country: United States
Make (manufacturer): Honda
Model: Accord
What have you tried so far?: Nothing yet. Vehicle is a 2013 in sport trim.
Chat:
OnlineMasterTech :
Hello I will be glad to help you with your Honda questions today.
OnlineMasterTech :
Let me take a look at the schematic to see if the ANC can be disabled.
OnlineMasterTech :
You can actually disconnect the Active Noise Control unit which is located behind the center pocket. Let me know if you need anymore help on how to remove the connector.
BiminiRoad :
Where is the center pocket and how do I gain access to it? How can I identify the ANC unit?
OnlineMasterTech :
Let me see if I can get some directions for you.
OnlineMasterTech :
Click here for ANC unit removal
OnlineMasterTech :
Do you have Navigation?
BiminiRoad :
I do not have Navi. Thanks for the diagram, but it says I have to remove Hands Free Link unit first. Are there separate instructions for that?
OnlineMasterTech :
Yes I was getting ready to post those for you.....just needed to know if you have NAVI or not.
OnlineMasterTech :
I will get them right now. Please print these instructions off as I will delete the link when we are finished.
OnlineMasterTech :
Full Size Image
BiminiRoad :
The ANC removal PDF link worked, but the image you posted did not work
OnlineMasterTech :
Click Here for center pocket removal.
OnlineMasterTech :
Click Here for pocket trim removal
BiminiRoad :
Ok, I got all the PDFs, but the Hand Free Link removal I don't have
OnlineMasterTech :
Click Here for HFL removal
OnlineMasterTech :
Ok that should be all of them.
BiminiRoad :
Ok got it. Can you tell if if there will be any negative side affects of the ANC unit being disconnected?
OnlineMasterTech :
Nothing that you will probably notice. You may hear a little more road noise than usual but it will be minimal......especially if you are adding an amp and using the radio frequently.
OnlineMasterTech :
Do you have any other questions for me today?
BiminiRoad :
Ok, but no diagnostic codes should come up, right?
OnlineMasterTech :
No none that I am aware of unless this system has been changed since the 2012 model.
OnlineMasterTech :
I do not see any information in my database that would suggest that a code would be set.
BiminiRoad :
On the pocket trim removal, does this simply pry up with a small, flat tool?
OnlineMasterTech :
Yes you would want to use a plastic trim removal tool to prevent any type of damage to the trim pieces.
OnlineMasterTech :
I like using a plastic paint scraper to remove the panels
BiminiRoad :
Ok. Installation is the reverse of the removal steps, correct? It seems that way.
OnlineMasterTech :
Yes that is correct.
BiminiRoad :
Excellent. Thank you!
OnlineMasterTech :
No problem at all. This new model Accord is a great car and I hope you enjoy it.
BiminiRoad :
Thanks so much. Good day to you.
OnlineMasterTech :
Please remember to rate me at Excellent Service and Thank You for letting me assist you today!
BiminiRoad :
Of course.
OnlineMasterTech :
You have a great day also!
BiminiRoad :
In summary, here are the steps:
1. Remove the center console side trim
2. Remove the center pocket
3. Remove the navigation switch panel if you have Navi (I don't so I don't have a diagram for that)
4. Remove HandsFreeLink control unit
5. Remove (or simply disconnect) ANC/ASC control unit
If anyone does attempt this in their vehicle before I do, please post some pics!
Cheers
@Husker it looks like for NAVI, you just have to remove an additional switch panel. I got my answer already, so I paid. If you try this out, it may be something simple (i.e. fasteners and wires to disconnect). Otherwise, you can pay the man as they say. I found JustAnswer to be just as advertised.
Either way, please contribute to this thread if you do find out.
I'll have to check out that site.
Yep, I think it will be easy thanks to you-->:thumbsup:
