Yep exactly that.
More like 3.5 quartsIdk I thought the dipstick hole was half an inch but I went to make sure my new funnel would fit and it's a 1" tube, it should go in there pretty fast, and for my 2015 V6 it should be like 2.5 something quarts I have to just pre measure and pour in
I think it's double the size over my 8th gen it's also way lower down but it's definitely largerThe dipstick tube must be larger on the 9th gen, than it was on my 7th gen V6.
I have still yet to find the exact amount since you have to pre measureMore like 3.5 quarts
i have a 2015 Crosstour 4WD, it may have a different transmsision setup. ive looked through 50 websites and can not find the exact Amount of Quarts of DW 1 i need to buy for a 2015 Honda Crosstour TransmissionThis is from the 2016 owner's manual.
Specified Honda ATF DW-1 (automatic transmission fluid) Capacity Change 3.3 US qt (3.1 ℓ) ■Engine Oil ■Engine Coolant Recommended ·Genuine Honda Motor Oil 0W-20 ·API Premium-grade 0W-20 detergent oil Capacity Change 4.2 US qt (4.0 ℓ) Change including filter 4.5 US qt (4.3 ℓ) Specified Honda Long-Life Antifreeze/Coolant Type2 Ratio 50/50 with distilled water Capacity 1.72 US gal (6.5 ℓ) (change including the remaining 0.17 US gal (0.64 ℓ) in the reserve tank) ■Tire *1: EX-L V6 models *2: U.S. Touring models and Canadian V6 Touring models Regular Size 215/55R17 94V*1 235/40R19 96V*2 Pressure psi (kPa [kgf/cm2 ]) 33 (225 [2.3])*1 33 (230 [2.3])*2 Front Rear 33 (225 [2.3])*1 32 (220 [2.2])*2 Compact Spare Size T135/90D16 102M*1 T135/80D17 103M*2 Pressure psi (kPa [kgf/cm2 ]) 60 (420 [4.2]) Wheel Size Regular 17 x 7 1/2J*1 19 x 8J*2 Compact Spare 16 x 4T*1 17 x 4
Have you downloaded the owner's manual from the Honda owner's website? It likely has a lot more information than the printed manual that comes with the car. It does in my car's case.i have a 2015 Crosstour 4WD, it may have a different transmsision setup. ive looked through 50 websites and can not find the exact Amount of Quarts of DW 1 i need to buy for a 2015 Honda Crosstour Transmission
My manual doesn't sayHave you downloaded the owner's manual from the Honda owner's website? It likely has a lot more information than the printed manual that comes with the car. It does in my car's case.
It says 2.6qt. seems like not enough but I guess I only need 2.6It would be on the specifications page near the last page of the manual.
I was looking at the four cylinder. Mine's a V6, 3.28 quarts. I guess that seems normalIt says 2.6qt. seems like not enough but I guess I only need 2.6
