1 - 8 of 8 Posts
Hello guys, I have an ABS light that has been on for a while now (came on after I swapped out my winter tires last season.) I have a code reader that reads ABS codes but when I hook it up I don't get anything. How can I pull ABS codes on this car? I am having trouble with my brakes. They feel very weak and I feel like I'm fighting with them to stop the car.
Reason why I'm asking about the ABS is because I want to try and bleed my brakes, but I've heard air can get trapped in the ABS module and I want to try and lock up my brakes to activate the ABS to push any air out of the system before trying to bleed the brakes.
Basically, I want to bleed my brakes but before I do so I want to try to engage the ABS just in case there is any air trapped in the module. I don't really care about replacing any ABS sensors for any other reason then this.
Obviously I can't trigger the ABS if the light is on, right? Any help would be greatly appreciated, thank you.
Cruising in Montana
No need to worry about the ABS module when bleeding brakes. Just crack open the bleeder and have at it.
Honda's recommended way: front left, front right, rear right, rear left.
You could also find a dirt road nearby and brake hard enough to cause the ABS to activate, then putter on home and change the fluid.
What if there is air in the ABS module though? I heard air can get in there or something.
The ABS will not activate right now from what I know, because the ABS light is on. Is that not true?
Turbo lag
Discussion Starter #6
Discussion Starter #7
The ABS may or may not work with it on. The normal brakes will work just fine though.
Go find a dirt road and test it.
Ok will do, thanks. From what I remember, when I locked up the brakes before, ABS didn't work. This was when the light was on. I'll give it another shot though.
Turbo lag
Is this safe?
It should be. It's not a hack, it's just taking advantage of how the car works. If you plug in the HDS, it'll short the pins together anyways when you run the test mode.
1 - 8 of 8 Posts
