Vacuum Lines
Not a full chapter, but still important.
In response to @Inspire2.4 's question from 11 month ago, I did attempt to set up a constant vacuum with a catch can for the PCV and valve cover vent in March. It did NOT work.
I don't have any actual picture, but this is how I setup the system.
The catch can did collect a bit of oil and moisture, but this setup clearly did not generate enough vacuum. The crankcase pressure was high enough to push oil past the oil control ring on the turbo from both the compressor side and the turbine side. I ended up with an exhaust and an intake system completely drenched in oil. It took me 6 hours to completely tearing down the charge pipes and to clean them with soap, water, and goo gone. I went back to venting the crank case to atmosphere and leaving the PCV system stock.
