i tried this and got no response from my system, am i doing something wrong?1. Turn the ignition ON (II)
2. Press the AUTO button and then the OFF button.
3. Hold BOTH buttons down for 1 minute.
If there is an error the temperature indicators will flash between 88 (all segments lit) and the DTC indicated by the number and position of the segments lit in the display.
This is a code not an actual number. The Driver and Passenger temp displays numbers are made up of seven individual segments, each turned on or off to make the required digits appear.
Each lit segment indicates an Error code. If all segments are lit for each number you will see 88 in the driver and 88 in the passenger display.
The only reference I found to the display panel not running self diagnosis was to check for loose or poor connections in the panel and if none, replace the panel.i tried this and got no response from my system, am i doing something wrong?
It did not even seem to go into diag mode (i would expect lights to flash and motors to move...)
I believe the 4 cyl is the same sequence for the same Climate control unit.07EXAccord said:Is the 4 vs 6 HVAC display different?
