Ok this is my first write up ever but here goes nothing. I will need to take more pictures to show more steps but I did not like the lens I had brought. I feel this will show what has to be done.
Part Number is the following:
HYB-SCB-01-07
Link: https://www.hybrid-racing.com/collections/drivetrain/products/performance-shifter-cable-bushings-hyb-scb-01-07
You will need:
Flat Head screw driver
Philips screw driver
10 mm socket
12 mm socket
Needle nose Pliers
Plastic Rivet removal tool
Step 1 - Battery Removal
Start by disconnecting the battery terminals, put the cables out of the way.
Remove the battery tie down with a 10mm socket, make sure to hold onto the J hooks as they will fall.
Remove battery and plastic covering under it.
Step 2 - Air Box Removal
Remove the 4 clips holding in the air duct.
Unhinge the 2 clips on the air filter cover and remove air filter.
Unclip the Sensor along with the plastic rivet holding the cables to the air box.
Loosen the clamp on the rubber hoses and remove the upper air box
Remove the 2 10 mm screws holding in the bottom air box.
Pull up and remove the air box (2 rubber bushings holding on under the box)
Step 3 - Battery Holder Removal
Remove the 3 12mm and 2 10mm screws holding on battery plate on top.
Remove cables attached by 2 plastic hooks on battery holder
Remove final 12mm screw under the ECM (Right screw in picture)
Remove battery holder
Step 4 - Replacing Bushings
With a pair of needle nose pliers, remove the cotter pin from the top of the cable bushing.
Remove the top metal shim.
With a flat tip screw driver, pry the metal insert out of the OEM rubber bushing.
Install the Hybrid Racing bushing with the logo side up for the larger bushing and outwards for the smaller bushing
Open the retaining ring and carefully slide into the groove on the bottom of the cable bushing.
Be sure to slide the retaining ring around to ensure it holds the bushing in place.
Install the supplied cotter pin.
Now you can put it all back together and enjoy!
Make sure you plug the sensor back in!!
:grin
HYB-SCB-01-07
You will need:
10 mm socket
12 mm socket
Needle nose Pliers
:grin
