our '17 EXL hybrid has 22k miles. i'm not sure when B3 service light will come up.
at what mileage you change transmission fluid on a hybrid?
It says when to change it, in your manual, code is number 3.our '17 EXL hybrid has 22k miles. i'm not sure when B3 service light will come up.
Wrong.A '17 does not have a CVT and there is no belt.
These articles and video are wrong then?Wrong.
The Hybrid has a CVT and an all steel belt just like the 1.5L CVT has. Honda even calls it a "eCVT". Articles and YouTube videos that say it has no transmission are not accurate.
So the Hybrid has a transmission. It's an eCVT. But instead of CVT fluid, it uses DW-1?
Yes, there is a transmission one that even uses Honda's DW-1 ATF.So the Hybrid has a transmission. It's an eCVT. But instead of CVT fluid, it uses DW-1?
Absolutely wrong. 9th gen Accord 2013-2017 does have CVT for 4 cylinder engine or regular transmission for V6 engineA '17 does not have a CVT and there is no belt.
That said, I have 46K and haven't had any messages other than oil changes yet.
Sent from my Pixel 3 XL using Tapatalk
Sent from my Pixel 3 XL using TapatalkAbsolutely wrong. 9th gen Accord 2013-2017 does have CVT for 4 cylinder engine or regular transmission for V6 engine
both right... Lazytomcat was referring to strictly ICE cars I believe....The hybrid is different than the regular gas cars...Sorry, you are absolutely wrong...
Normally the electric motors drive the wheels. When the ICE drives the wheels is does so through a clutch at a final drive ratio appropriate for speeds > 40mph to highest speeds.
'13 -> '15 use a completely different hybrid system and drive train than '17 and up; read the letter from Honda and watch the videos.
Why wait, you may want to do it now.I'm at 53,000 miles and haven't had the transmission fluid change code come up on me yet on the maintenance minder. Just had the oil changed for the fourth time a few weeks ago it didn't come up then so I'm guessing next year it will come up around 63,000 miles when my next oil change is due.
Just a point to make, the 9th gen Accord Hybrids, and since, do not have transmissions in the normal sense. There is a gear train of course to get power to the drive wheels but no transmission. Even though Honda refers to it as an eCVT it is nothing more than the electric traction motor providing the go power up to ~45 mph and after that a clutch can add in power from the gas engine as needed. I think it's best to understand that since it does not operate anything like a regular CVT at all and therefore its needs for fluid change may be different.our '17 EXL hybrid has 22k miles. i'm not sure when B3 service light will come up.
