What brand/model tire is that? Was it like that since it was installed?
Sent from my Pixel 3 XL using Tapatalk
Trans Marine Propulsion System?A bit later, when TMPS flashed, I checked everything again, inspected the tires, and calibrated TMPS
Sorry, I edited the post to add some more info. It's a Continental Contiprocontact. And it wasn't like that when it was installed, of course. I really care about my cars and tires despite appearancesWhat brand/model tire is that? Was it like that since it was installed?
Looks like it happened out of a sudden when left the highway gate, but I didn't notice it blaming faulty electronics for all the issues. I was driving like that for some 300 miles because I went to the seaside and had to get back. As I said, at first sight nothing worried me as far as wheels are considered.So, this is something like cord separation in the sidewalls of the tires? And, you only have that deformation on the one tire? Interesting it hasn't shown wear along the edges of the tire.
- Jack
Nope. It was the other side and was replaced immediately.Is this the same tire that you hit the curb with??
Car is drivable, but EPS, VSA, ABS, BRAKE lights are on...
Hi everyone, I was driving one day and suddenly I see my EPS, VSA, ABS, and BRAKE lights turned on. I don't feel or notice anything odd about the drivability of my car. I stopped my car, turned off my car. I restarted my car, and the VSA, ABS, and BRAKE lights remained. However, the EPS light...www.driveaccord.net
Yeah, I appreciate my luck. I would have certainly tried to do sth. about the issue If I had noticed anything wrong with the tire. Unfortunately, I was focused on the radar issue (I still am) and neglected other possibilities. Moreover, I was stuck in the middle of nowhere looking for a quiet place to rest during the holidays.That belt shift is so common with Continental tires. What is surprising is how much tread is left. Usually as they wear down, I've seen hundreds of Continentals do that across their car and light truck tires. I also see it quite often with old Goodyears.
You are VERY lucky the tire didn't self destruct, as the belt really has no connection to the inner part of the tire and the faster you go, the more chance the centrifugal force will throw the steel right through the outside of the tire, quite spectacularly.
There was no bulge on neither sidewall. That's why I didn't notice anything. The inner third of the contact surface kinda lost its reinforcement. I don't know how to call it in English. Happily, it didn't make the tire burst. And this is how it looks inside - the inner (upper in the photo) part is deformed.A bulge on the inner sidewall? It's called cupping if I'm reading it right. If anyone experiences this, run your hand over the inside of each tire.
