1 - 20 of 20 Posts
So I've been using the same dealer where I purchased my car, Honda of Watertown in CT. I just had a B1 service today and, while satisfied, I have some complaints and observations.
I left a note on the dash specifying my needs and situation. My tires need to be replaced, left rear leaks 5-6 pounds per month. I replaced transmission fluid 2 months ago. Please don't top off washer fluid. In addition to my note, I told the desk clerk who was handling my appointment
An hour later while i'm at the grocery store across the street, I get the call with their concerns (by the same clerk). Transmission service is recommended, my tires need replacement, car is done. I'm like "did you even read the note?" but I kept that inside and just said thanks.
Upon picking up, I am also told that I need a fuel injector service and that my battery terminals are heavily corroded and need cleaning. I use Top Tier (Shell) fuel for every fill and toss in an injector cleaner roughly every 10 fillups. I have attached pictures of my "corroded" terminals. They looked this way last month, and still do today.
On a final note, she told me they set my tire pressures to 33. I checked at home and I had 3 at 40PSI and 1 (rear left) and 34PSI. I got my oil change for free (as agreed upon when I purchased the car), and that's all I wanted so I'm happy, but sheesh, they SUCK at everything else
Cruisin'
They tried to make those extra dollas and it made you holla!
LOL
Joking aside, sorry to hear about that. Unfortunately there aren't too many morally sound mechanics/dealers out there. SMH When I went in for my 2nd oil change (around (15K miles)
the service advisor said, we found carbon deposits in your throttle body and your transmission fluid should be changed. I said hmm, well when I had my 2003 Accord, the throttle body never had carbon build up...how could this newer and "better" car have that? Could you show me? He said, the next time you come in we can show you with a video scope. About the transmission: I said I believe the transmission fluid is supposed to be changed every 30K miles right? Advisor said, think of it this way: when you cook with oil and use it repeatedly it starts to discolor right? That's how it is in the transmission, due to the heat.
:: FACEPALM :: I am going to go by the book and not the crook! :)
Mike, the leaky tire could be a leaky valve stem seal, or perhaps the bead on the tire. A spray bottle of soapy water sprayed on the valve stem seal and the rim where it meets the tire will reveal the culprit.
One of my tires developed a slow leak- I found it was the valve stem seal by using this method. Tires were fine.
I could eat off of your battery terminals....
Reactions: enne
To make it worse you probably have no idea what brand or weight of oil they used or if they replaced the oil filter. It's what I have said before, the kid working in the lube bay might well have been flipping burgers a Micky D's the week before. Looks like you have also found a service manager that can't read.
I have had similar problems with the Honda dealer where I purchased my car, McCurley Honda in Kennewick, WA. After doing an alignment they sent me on my way with a car that was wondering all over the road and actually unsafe to drive. I took it, the next morning, to a good tire shop and had it realigned. After showing the Honda dealer the as found and as left alignment data from the Hunter equipment at the tire shop the dealer did give me my money back but wouldn't tell me what went wrong.
There are a lot of fly-by-night auto repair places but some new car dealers seem to be the worst of them. Yes, I know there are a few good ones left but they are getting hard to find. Best solution I have found is to either DIY or find a good, reputable, independent mechanic.
Well I have 65k on the tires and have plugged one of them already, so once I replace, I'll have the valve stems replaced as well. That slow of a leak will be hard to spot, its like 2lb a week or less. I'll check anyway since you mentioned it.
As for the terminals, I have a can of the battery terminal spray and a wire brush ready for the day I see buildup. I'm LOOKING for problems and not finding much, yet these clowns are trying to perform unnecessary service
I'm going to start marking the oil filter to see if it gets replaced
If it were me I'd be emailing the service manager and general manger of the dealership. With pictures. I'd focus on the tire pressure and battery terminal issue because you have hard evidence that they either lied, made stuff up, confused your car with another or some other a$$clownery. Something along the line of "If I can't trust you over simple things like tire pressure and battery terminals, why would I ever trust what you tell me about transmission fluid, fuel injectors or other more complex systems?"
8th Gen Believer
Ditto. Although I like my dealer, they -- it appears -- have the same three sentences printed on their invoices under the heading of "work needed but not done." One is bleed brakes and refill, the second is transmission fluid black and smelly, the third is need 4-wheel alignment. I'd had ALL of that done two months ago. I compared two invoices with the same b.s., called my service advisor and she kinda stumbled around and said to speak to her in person next time I'm there, upon which she confessed ,,,, they try to scare people, unknowing people, into another appt.
Discussion Starter #8
If it were me I'd be emailing the service manager and general manger of the dealership. With pictures... Something along the line of "If I can't trust you over simple things like tire pressure and battery terminals, why would I ever trust what you tell me about transmission fluid, fuel injectors or other more complex systems?"
Fortunately, I'm willing to do the work myself to $ave, so I'm not at a high risk of them botching one of those jobs. HOWEVER, there will come a task that I need help, and on that day I may bring my business elsewhere. I will continue going for oil changes because their rate for Hondas is $18.95 for full synthetic + filter.
1 the second is transmission fluid black and smelly,
2need 4-wheel alignment.
1- As far as I can tell, for the MT it is not possible to check trans fluid quality without draining it, so they at least can't hit me with that nonsense, but my fuel injection system notice sounds like one of their "60,000 mile service" reminders along with my transmission fluid recommendation. There is no mention of injectors in the OM, plus I know that system is functioning properly by operating under the assumption that great gas mileage and/or a quick throttle (for a 4cyl) indicate proper function.
2- I've been alerted to misalignment every other appointment, and the misaligned wheel is different on the chart each time. My tires wear evenly, my vehicle tracks straight and rides smooth, I'm not paying for an alignment when I plan to replace 4 tires in the next 5k
I must be lucky, I've never got hit with any of this stuff at the dealer we use for service. They are good about coming out and telling me about stuff then taking me back in to the service area and showing me if there is anything they find over my initial request. They also use an online scheduling app that lets you get pretty wordy in what you want them to do.
That being said, I do all my scheduled maintenance myself and only go back when there is something I don't have the time or tools to manage myself.
I'm surprised you didn't get charged to put summer air in your tires...
Discussion Starter #10
... They also use an online scheduling app that lets you get pretty wordy in what you want them to do.
Online scheduling would be helpful, and my dealer may offer this. I only go in for oil changes for the price (free up until now, and 18.95 from here on for full synth). Summer air, ha...
They made my day this afternoon, I received an email offering for me to fill out a survey and asking if they can count on me to rate them highly in a survey from Honda. I'll be sure to include pictures when I fill that one out...
Discussion Starter #11
This was my response to the email from the dealer
Katie,
Below, I have responded to the questions in your email.
Do you feel like during your most recent service visit that you were provided with excellent service?
From Stephanie, Yes. Otherwise, No.
I explained my maintenance history to Stephanie and left a note on the dash for the service technician with the same info as well as asking not to top off washer fluid. My fluid is green RainX, the top of my fill spout was blue after servicing. I also reported that I changed my transmission fluid at 55,000 miles, but received a notice from the technician that a transmission service was recommended, which suggests the note was missed or ignored. This is minor, but still a complaint.
The technician reported that a fuel injection service was recommended, while the Owners manual does not make any mention of such a service, but this is minor. The manual recommends use of Top Tier fuels, which I use, and I have seen no loss of power or fuel efficiency over 65,000 miles of ownership.
Technician also reported that my battery terminals have signs of corrosion or buildup and recommended cleaning. This was not true, I inspected my vehicle before embarking on a cross country drive in May, and saw nothing wrong then, nor do I see anything wrong now. Maybe he confused my vehicle with another, which on its own is also minor, but it raises other concerns that my vehicle may not have received the service that was intended. I have attached images of the condition of my battery terminals that clearly indicate there is no such corrosion or buildup.
Lastly, the sticker indicating the recommended next service date was not replaced, further suggesting that my car did not receive the full attention of the technician during the standard inspection that goes with a B 1 service. I will be concerned in the future that the oil filter is actually replaced when promised, and will take steps to double check that a new filter has been installed after my next appointment. Am I receiving synthetic 0W20 oil, or is the technician using something else?
All of my complaints are of little concern on their own, but combined together, they suggest a casual or total lack of attention to detail by the technician, as well as tactics to pressure me into paying for unnecessary services to my Honda.
Did Stephanie review the multipoint inspection with you?
After I explained my at-home service history, Stephanie acknowledged that I understood the items included in the inspection.
Did Stephanie mention to you that you may receive follow-up / survey e-mails?
No that I recall, but I often do receive such emails.
Can we count on you to provide us with excellent ratings if you are selected to receive these surveys?
Not excellent. The service advisers have always been helpful and informative. The quality of my service has been more than satisfactory in the past, but my most recent visit has broken my trust.
Thank you,
Michael
Discussion Starter #12
The saga continues with my first world complaints over my service department.
Just had another oil change with tire rotation (included with my tire purchase). I have 3 slightly damaged rims, so I made a note of where they had been on the car. The dealer rotated my tires front to back without crossing any from side to side, I have non-directional tires. They also did not reset the TPMS, which I would assume to be standard by now. Otherwise, they did a good job of reading my note that said not to touch anything else on the car. It annoys me when they add the regular blue washer fluid to my full reservoir of orange or green Rain-X.
Your TPMS would not need to be reset unless it was set wrong when you took the car in. The 1 lb difference front/rear recommended by Honda is irrelevant. Judging from your past experience I would recommend checking your own tire pressures then reset the TPMS yourself if needed.
For your own peace of mind and safety I suggest finding another place to have your car serviced.
Bout it, Bout it
I haven't had any shop follow the cross-rotation pattern listed in the owner's manual before. They always just rotate side-to-side. Maybe it's a time issue, maybe it's easier to do the same pattern on all cars, maybe the techs can't be bothered to take 5 seconds to see if the tires are directional, IDK.
And at least your dealership adds washer fluid. The last two times I've gone in, the low fluid light was on when they brought my car around. Of course, the inspection sheet showed the fluid was full lol
You guys waste time and money at the stealership? These are definitely first world problems.
I changed out my front struts in less time than it would take me to drive to the stealer.
Discussion Starter #16
You should reset the TPMS every time you change air pressure or a tire is moved to a new corner of the car. I had 3 at 38PSI and one at 37, the TPMS light came on about 100 miles after the service. I hit the button and it never came back, but I reset my tire pressure last night in my garage on all 4 wheels. I'll continue to go to the same dealer for the oil changes since they charge $18.95 for semi-synth and a filter, and I just walk to the grocery store while I wait.
Everything else I do myself (trans fluid, rotors and pads, lights, filters, tire patching), but it costs more to buy the oil and filter than they charge to do the whole job.
Reactions: KW2004Accord
How on earth is this possible? What do they charge for the change? We did have a Meineke in the neighborhood that was doing $10 oil changes for a while. Turned out they'd tear your CV boots in order to drum up business. I have a hard time believing a dealer is doing cheap oil changes.
It's the time that kills me. I do an oil change in 10-15 minutes. The drive to anywhere is that. Then add on the drive back and the time to wait. If you don't wait there's the time to get another ride to wherever and then back.
Discussion Starter #18
It's $18.95, and I live about 1.5 miles away. My usual grocery store is across the street and there's a Dunkin Donuts next door. Since I schedule my appointments for Saturday mornings at 7:30, I walk to Dunkin, then the store, then my car is ready
I gave one of my local Honda dealers a test. I even told the service writer that it was a test. That if they did this right I would be back. If not, they would never see me again.
I scheduled an appointment to do the B pillar wind noise TSB fix. Needed to order parts and would call when they were in. I waited. 3 months later I called back. Never ordered them but would now. Brought the car in the following week. When done I asked the service writer to explain what repair procedure they had accomplished. He didn't know and had to go ask the tech. And then he came back and said they had replaced the garnish on the passenger side. Only. Not the driver's side. And then looking closer at the TSB, they didn't do anything resembling the procedure outlined in the TSB.
Long story short, this simply confirmed my belief that if I want it done correctly, I need to do it myself.
But I do have a trusted indy shop where I can speak to the actual guy that does the maintenance. I can't stand the dealership arrangement where you can only talk to the service writer and not the guy that does the work.
No more dealership service for me. Ever.
V4 Watch
Having worked at an auto shop, I can give you some explanations on how some of these things go down. I'll also let you know that I was a very hard working and HONEST worker who didn't recommend stuff that wasn't needed. I quickly built up a reputation of someone who could be trusted, we had two technicians there, both of them trusted me. Both of them also didn't exactly trust some of the other people...
The thing is that the quality of your service depends on the INDIVIDUAL who works on your car. I worked at Goodyear, my shop had generally honest people. I was a very high quality worker at Goodyear. However, just because another shop shares the same name, you aren't guaranteed quality work. Would I trust a different Goodyear to work on my car? Probably not.
That being said, there are generally two types of cars that come into shops:
1. New cars that might need minor things or nothing with owners who are willing to buy things.
2. Old cars that need work but the owners completely neglect maintenance and don't buy anything.
I would suggest you tape the note to the steering wheel, or give the note to the clerk. My shop used tickets which had any special instructions or notes indicated on them. It is possible that their ticket had no indication AND the tech didn't see the note. The tech not checking your tire pressure is pure laziness on their part, I checked the tire pressure of pretty much every car I worked on. Some of the guys that I worked with would only check it if they were visibly low, if it was indicated on the ticket, or if the TPMS light was on.
Most often there is a puncture in the tread, sometimes in the sidewall. Leaking valve stems are EXTREMELY rare. When checking the stem, make sure to spray the soapy water around the rubber AND inside the valve area.
Battery terminals are made of lead, you don't want to eat off of them. :smile
Understandable.
I believe you can check the level, I think there is a check bolt that upon removing will drip a small amount of oil if it is at the correct level. No oil coming out means there is not enough, a steady stream indicates too much oil. The problem is that in order to check the level, they would have to spend an extra 10 minutes or so, and risk breaking stuff. The real problem is that as workers, we are given a sheet and told to fill out everything about the condition of the car, even if it has nothing to do with the service being performed. We are also expected to work very quickly. The service providers get nervous when customers get antsy and walk around. This promotes workers just checking off everything as okay, or a commonly needed item as not okay. Don't trust the sheet unless you request an actual inspection of specific areas. If something is indicated as needing replacement, make sure to ask them to SHOW YOU.
Sounds like they didn't read your note regarding the fluid condition. As far as injectors, they have no way of knowing that you use injector cleaner unless you tell them. Injector services are easy money for shops, they sound reasonable enough for the average person and they don't cost all that much either, so they are easy to sell.
At my shop I was told to rotate front to back, not the X pattern, so that is what I did. I usually only reset TPMS if the car got new tires or if I knew it was a car that used the wheel speed sensors seeing different rpms to detect tire pressure.
TPMS should only be reset if it was set to an incorrect tire pressure or if the tires were rotated/replaced, you don't need to reset it every time you change pressures.
1 - 20 of 20 Posts
