I heard the new injen intakes have annoying resonance at around 4500 rpm. Any that currently have this installed find a similar problem? Anyone recommend waiting for the K&N?
absolutely not true. the only time you hear the thing at all is when you hammer down on the gas, and even better, when VTEC kicks in after 5K RPM. you will not regret buying this. trust meI heard the new injen intakes have annoying resonance at around 4500 rpm. Any that currently have this installed find a similar problem? Anyone recommend waiting for the K&N?
Cold air intake now available for the V6
http://www.carid.com/2013-honda-accord-air-intakes/injen-air-intake-7298317.html
And by "hear the thing," I assume you mean the intake and not the resonance.absolutely not true. the only time you hear the thing at all is when you hammer down on the gas, and even better, when VTEC kicks in after 5K RPM. you will not regret buying this. trust me
correct. you hear the growl of the intake. there is no resonance whatsoever, at any RPMAnd by "hear the thing," I assume you mean the intake and not the resonance.
Thanks for the imput!
Thanks mancorrect. you hear the growl of the intake. there is no resonance whatsoever, at any RPM
It gets pretty loud at 4500... I love it but sometimes I wonder if I'll get annoyed in the long run. I went with black and it looks great under the hood.I heard the new injen intakes have annoying resonance at around 4500 rpm. Any that currently have this installed find a similar problem? Anyone recommend waiting for the K&N?
My scoop feeds to the stock airbox where I fed the SRI. Works like a charm and sounds great.The V6 could utilize the scoop, but would need the filter to lay behind the headlight housing.
I thought the V6 factory intake system was a cold-air style. Am I wrong here?For those of you perennially undecided about whether to go with a cold-air intake or a ram/hot air intake. Here is you answer quoting directly from the article:
It's a well known fact that cooler, denser air contains more oxygen, and more oxygen in your engine's air intake charge means better combustion and more power. Hot air contains fewer oxygen molecules, and if your engine is fed hot air there will be less oxygen and therefore less power. Yet that's exactly what your engine gets with the factory air intake system! The solution to this problem is to install an Injen SP Series Cold Air Intake System.
Injen starts the power improvement process by positioning an Injen EA Nanofiber dry air filter behind the front bumper. Here, this free-flowing filter can take in the coolest air possible and funnel it through smooth, mandrel-bent 6061 aluminum alloy tubing.
Glad you brought this up - I was looking at this the other day and that's what it seemed to me (that it was bringing-in fresh air)I thought the V6 factory intake system was a cold-air style. Am I wrong here?
Yep it is CAI style so I basically fed the SRI into the CAI box and with a heat shield and the higher flow of the Takeda Filter I think you get the best performance you can. I really think the CAI is a waste of your time on the v6 when it is already designed this way.Glad you brought this up - I was looking at this the other day and that's what it seemed to me (that it was bringing-in fresh air)
Agree - a SRI, and hi-flo air filter should do a good job unless you are going all-outYep it is CAI style so I basically fed the SRI into the CAI box and with a heat shield and the higher flow of the Takeda Filter I think you get the best performance you can. I really think the CAI is a waste of your time on the v6 when it is already designed this way.
I spent thousands of dollars on my pristine 3 Series super charged BMW by the time I sold it and bought my 2015 Accord EX-L Coupe.Yep it is CAI style so I basically fed the SRI into the CAI box and with a heat shield and the higher flow of the Takeda Filter I think you get the best performance you can. I really think the CAI is a waste of your time on the V-6 when it is already designed this way.
