1 - 4 of 4 Posts
Hi. i have accord 2.0 98'
my inlet heater hose is leaking, i search on a new one in ebay but not found it.
i ask for help.
thx :smile
photo from 97' accord to same hose.
I think this is the part that you need:
79721-S84-A00
I ruptured mine and the guy at the dealership said it was common if you have a distributor that leaks oil onto it. The oil breaks down the rubber over time causing it to fail.
Ditto!! Extremely common occurrence and easy DIY. I've replaced several in different cars. While you're at it, also change the two breather hoses at the manifold. They're called Breather Hose A and Breather Hose B. They're probably overdue and all are very cheap to replace. Get all three at the Honda dealer.
Discussion Starter #4
79721-S84-A00
thx.
yes i have distributor leaks on.
i have to change also the distributor next.
1 - 4 of 4 Posts
