YesDoes anyone know if the cross member that the forward seat rails mount into would be a decent grounding point (assuming paint rubbed off and a bolt threaded in)?
Those two plugs are where the 4 cylinder models O2 sensors wiring comes into the car. Here's the parts digram for a 4 cylinders exhaust w/O2's ("A" & "B").I was investigating installing an amplifier under the passenger seat. ........
Also, under this flap are two rubber plugs in the floor of the car. I pried at them a bit and they seem like with sufficient force they would pull out. What is this about? I could only presume them to be drain plugs in the case of a flood. But then, why are there 2 right next to each other?
Good idea on that. I still have an extra Metra harness when I bought a new lower pocket single din kit to replace my broken one. I hated that they didn't include the two steering wheel control wires on the pass through harness.The problem with the one piece harness is that it is (in my research) ever so slightly more expensive than the two separate harnesses which is compounded by the fact that I have to buy 2 because they all are missing at least one wire for the steering controls.
I went ahead and made a full 20 pin harness on both ends from the wires salvaged from the the spare harnesses. So long as the factory connections aren't total blanks that would block those pins from inserting this should keep me from getting into the dash and realizing I missed a pin or put an otherwise missing wire in the wrong position.
