Saw a bunch of (older) posts but nothing new and no solid answers to this issue. Here's my situation: about 2 months ago, BOTH of my key fobs started acting wonky. The one key fob had NEVER been used. The other I have used for 10+ years straight after I bought the car in 2011. Anyway, started noticing the key fob would not lock my doors upon leaving vehicle. Tried 2nd (unused) one - same deal. I replaced batteries (on both fobs); no difference. Saw a bunch of posts suggesting wiping, turning batteries in compartment. Did that - no difference. Re-programmed key fobs per manual to correct lock/unlock set-up. no difference.
What I'm seeing is fob works initially in morning to unlock my doors, then after driving to work and exiting vehicle it won't lock (so I have to manually lock); then after about 10 minutes outside of car - it works again. When it 'doesn't work', the fob doesn't flash the red light when I push the buttons; when it does work, it flashes the light. It seems that somehow when I put the key into ignition the lock/unlock on fob is being somehow deactivated??? This happens now every time with either fob. Works at first and then drive the first time of the day, and then it doesn't work for about 10 minutes after removing key and going away from car; and then it works properly rest of day whether I drive several times or not at all. Again, when it works, key fob light flashes; when not working, key fob light doesn't flash. Anyone have a solution?
