Many have here and it's not normal.I have noticed while I've been driving on the highway that when I'm going about 60-70mph I can hear the wind almost as if the door seal isn't flush. Has anyone else experienced this? I have a 2015 Touring.
Thanks! It looks like this is indeed what I am experiencing. Will try to take to dealer sometime this week.Many have here and it's not normal.
You may need to see if this helps TSB 15-011
http://www.driveaccord.net/forums/4073633-post69.html
Please post the results if indeed it is the TSB related problem. TIAThanks! It looks like this is indeed what I am experiencing. Will try to take to dealer sometime this week.
I have it. It's terrible. Either I am sensitive or mine is particularly bad.Thanks! It looks like this is indeed what I am experiencing. Will try to take to dealer sometime this week.
Thank you, I had no idea that a TSB was released for this. Just figured I'd have to live with it.Many have here and it's not normal.I have noticed while I've been driving on the highway that when I'm going about 60-70mph I can hear the wind almost as if the door seal isn't flush. Has anyone else experienced this? I have a 2015 Touring.
Can you post a photo to show where you put the rubber and what the rubber looks like. thanks.It is Really Easy to fix this issue, I did by myself, 0$ cost. Took some 3D adhesive Rubber i had gotten from receive package at work.
Ive cut 3-4mm width.
Just put out the Rubber when the windows close.
Put the Rubber adhesive into the channel on the outside of the car side of the rubber. There is an Empty Channel of 4-5mm.
I don't know, having a empty space like that makes it easy for wind to come in.
There. Problem is fix 80-90%, it is now very aceptable. I don't really hear it anymore.
Its a weird feeling to not hear anymore something. Not like adding sound on an exhaust and yeahh !! lol
Did you have a chance to stop by dealer and apply TSB 15-011 to your vehicle? Thanks.Thanks! It looks like this is indeed what I am experiencing. Will try to take to dealer sometime this week.
I unfortunately did not get a chance, may go sometime next week. My build date is March 2015.Did you have a chance to stop by dealer and apply TSB 15-011 to your vehicle? Thanks.
Mine is April 2015 hopefully it has the TSB already applied as the TSB came out in March.I unfortunately did not get a chance, may go sometime next week. My build date is March 2015.
I made an appointment for next week, and will let you know. I hope it reduces wind noise level.I unfortunately did not get a chance, may go sometime next week. My build date is March 2015.
Read the TSB - it gives the VIN range that it applies to.So is this TSB valid for all cars in the model year? Is it included under warranty?
