Of course not.Is it possible to build a 500+ HP 2.0t??
Can't turn the Accord into a time machine no matter how much money you have.if you have the cash, anything is possible
if you have Doc and Marty on your team anything is possibleCan't turn the Accord into a time machine no matter how much money you have.
Our accords like most Honda's I have worked on have half shafts, and equal length drive shafts which do a great job on mitigating torque steer. I rarely encounter any torque steer on my tuned 2L.That's gonna be some really expensive torque steer...
appreciate that, i do have the 6 speed manual so it should handle the power a little better![]()
Final P600 Dyno Testing (Accord & Type-R) - PRL Army Blog
Test Vehicles: PRL Accord Factory K20C4 Engine and 10 Speed Automatic Transmission KTuner and Hondata PRL Type-R P600 Drop In Turbo Upgrade PRL Type-R Titanium Turbo Inlet Pipe PRL Accord HVI High Volume Intake System PRL Accord FMIC PRL Accord Race DP/FP Combo Factory Exhaust IMW Accord Factory...prlarmy.com
These guys got up to 466 WHP which is basically 500+ HP crank. You need FBO big turbo kit and race gas though. They also say at least the 10AT can barely handle it and starts to slip.
Yup and they aren't the only tuner that limits torque in lower gears to maintain durability/reliability of engine and transmission parts. VW also makes what is called a twincharger setup in a 1.4l. Yes your thinking of correct, sc for down low power turbo for up top. Basically what happening now is that manufacturers are trying to make as much horsepower with the least amount of displacement possible. The lower the engine displacement the less fuel it's using because most of the times the engine's running at stoic when you're cruising anyways. So what you're starting to also see are compression ratios raising, cylinder deactivation, etc. Manufacturers are in a race to lower CO2 emissions as quickly as possible because new regulations have mandated the phasing out of fossil fuel engines by 2030 in some countries.Back when Polestar was a separate Volvo tuner company, on their higher stages of tuning/mods for Volvo turbos, they would intentionally limit boost to lower levels in the lowest gears of the automatic transmission. This was for drivability reasons (no need for full power in the lowest gears, with a FWD drive train), as well as for reliability (not over-stressing the automatic transmission). Back then it was only a 5-speed auto, and from memory they limited boost in 1st, and slightly limited it in 2nd, and then allowed full boost in 3rd-5th. This was with a package that included a significantly larger turbo unit than stock, as well as exhaust mods, in addition to "re-chipping".
Even so, they were not going as extreme as the OP is talking about. From memory, they were getting maybe 350 hp, versus 230 or so from the stock turbo (back then, it was a 2.5 liter inline-5). With just re-chipping, and no hardware changes, they were probably getting about 300 hp, as the stock programming was very conservative in terms of boost.
Back then, even though Polestar was still a separate company, their mods were somewhat supported/sanctioned by Volvo, and even with the large turbo and other hardware mods, I think Volvo kept warranty support on the rest of the drive-train. Which is probably why Polestar limited boost and power in the lower gears.....
As a side comment, Volvo has stopped making their 2.5 liter 5-cylinder turbo, which used to be called the T5. Nowadays, the T5 name is applied to a 2.0 liter 4-cylinder turbo, making in the neighborhood of 250 hp or so. The T6 name, which USED to be an actual inline-6 turbo (3.0 liter, and transverse mounted - it barely fit...) is now used to denote the same 2.0 liter 4-cylinder engine as the T5, but in this case it has both a turbo AND a belt-driven supercharger, and provides 330 or so HP. I think the logic behind this is (probably) that they use a somewhat larger turbo than on the T5, but since it also has worse lag, they use the supercharger to get more instant boost.
A K24 in a Porsche?! That's probably a crime in Stuttgart.K24 with a Garrett turbo. Results are 21 minutes into the video.
