1 - 6 of 6 Posts
You're easy money.
I have an OEM replica spoiler from eBay I like it, it looks exactly the same and the paint was a perfect match. My only problem was the led light wasn't too bright, a year later it seems to have gotten even dimmer. I remember reading a while ago people replacing it with the clear led strip from the Si spoiler. I tried to search and couldn't find any thread about it. Any help or information will be greatly appreciated.
Premium Member
You're easy money.
I wanted to do this to my previous cars which also had Ebay spoilers and not-so-bright brake lights. Wanted to use the very bright OEM light but then found out it is a different length and hightly doubt it was going to fit
That was my only complaint about the Ebay spoilers
Premium Member
Thanks Avio, now what about actually replacing it. I know there's two screws underneath the light, is it as simple as just removing the screws and sliding it out?
It should be pretty straightforward, you will need to look at the images the site provided to verify with the one you remove from your spoiler for dimensions, fitting/mounting features etc.
You will likely have to do the wire splicing again as the aftermarket one likely does not use the OEM connector, my spoiler wasn't OEM either and I can see wiring splice for the power connection.
Ordered a replacement LED strip for the spoiler for my 2000 Civic from spoilerlights.com...
Replaced it and never had a problem later on...
I'd recommend them, but they are not cheap...
1 - 6 of 6 Posts
