For those that don't know, 6th gen v6 4AT. But yea, I seriously hope it's NOT gone because if it is, this is the worst possible time for this to happen to me financially.
Prologue:
Yesterday I drove my car to work like I would any other day. I parked, set the alarm and walked away into the office. For lunch, I went to my car to go out, turned the key and "click" is all I heard. I couldn't hear the fuel pump prime the engine. When I turned the key to start the car, I just heard a single "click".
Long story short, the problem was the starter. Had it replaced and my car started up no problem.
Symptoms:
1. My D4 light blinks. I know already that isn't a good sign.
2. My car doesn't seem to accelerate very quickly anymore. The best I can explain is as if the car's computer is forcing the car to stay in 3rd gear. Because I was stuck in traffic when this happened though, I couldn't accelerate fast enough to see if it'll shift into 4th gear.
3. Shifting my car manually, it seems that I couldn't get the car to forced into 1st gear, only 2nd gear. Shifting manually, I also noticed the following:
4. My code scanner detected a P0763 for the CEL. It described it as a "Shift" error. A quick look online for that code, all I found was "A/T concerns"
Possible solutions / Questions?:
1. Could this be related to some sort of sensor somewhere? I know there are a few sensors located on the exterior of the transmission. Could one of these have gone out?
2. Could the starter having gone out and being replaced have something to do with this since the starter is attached to the tranny and flywheel?
Prologue:
Symptoms:
- Shifting from D2 to D3 makes the car shift hard
- ATF is still red
