Hello all I have a 2016 Accord Sport 6MT (i4 2.4L) with 125,000 miles, I just stumbled on the Honed Developments clutch delay valve delete. This part goes on the master cylinder on the accord. Now I am confused because all of the forums that I have seen on here about deleting the clutch delay valve is inside the clutch slave cylinder. I was looking at the part numbers inside the accord diagrams and saw that the valve inside that everyone has been removing is called a "Screw, Bleeder", so now I am not sure what to do. I guess the master cylinder also has a delay valve and the slave cylinder does too. My question is should I remove both?
Should I really do this mod on my daily driver? Even if I drive spiritedly and shift fast most of the time, and do a couple of burnout launches a week? I just started driving manual about a month ago, I got used to it a lot so far. Since this is my first manual I am scared if I do the clutch delay delete that I will bring some "bad" habits with it (not sure if it's bad or not). One example is when I rev match or downshift at the incorrect rpm (maybe I undershot 500 to 1000rpm), the current setup with the delay valve still in I just lift the clutch to the bite point and keep it there until the clutch rev matches for me. Other things like hill starts and more. I am just worried that maybe I will need to relearn everything I knew about how to use the clutch. There are still sometimes where I can be smoother with my shifting, definitely not done learning and being even more smooth. Not sure if I should wait till, I get more comfortable, or just do it now
