1 - 9 of 9 Posts
Hey guys. I was looking in the engine bay of my accord sport and I noticed this silver object on the right of the alternator that has something that looks like a spark plug on top of it. Does anyone know what it is? Thanks
The exhaust goes out the front of the engine there, as there's no exhaust manifold in this engine. I believe that silver piece of metal is basically just a heat shield. Pre-catalyst O2 sensor is what you described as a spark plug, and then the first catalyst is the vertical wider cylinder just below that metal shroud.
^^ Exactly.
That's one cheap cat (#6 in the exploded view above). Would of expected it to be pricier. I guess they make up for it with the O2 sensor.
No PRND
Wait... there are people on a car forum that don't know that that strange metal pipe is that comes off the engine and continues down under the engine and to the back of the car? OP, don't listen to them. That's the intake. Honda started sucking air to the engine from the rear of the car and that thing on top is a spark plug. They use it to charge the intake air before it enters the engine. This allows them to use less fuel. Its called "Charged Air Combustion Kinetics", or simply CACK.
First time I looked at the newer Honda 4 cylinder engines I did a double take. I am interested in how much longer the catalytic converter will last now that it is in the engine bay, rather than underneath the car where Chicago's winter road salt could attack it and destroy it- costing hundreds of thousands of dollars and millions of lives:confused:.
Reactions: LAF
There's still a second cat down underneath the car, no?
1 - 9 of 9 Posts
