Those are not tiny Cat's. They are Flexible exhaust piping so the exhaust can bend with acceleration. It's a very nice Addition to his product.does the rv6 j pipe come with a pre cat delete, all i see is 2 tiny cats, are those the only ones, do i need a test pipe?
isnt the downpipe part of the j pipe?No that's why it's a Performance J-pipe Exhaust system.
Only thing left would be the OEM Exhaust resonator which is located in the Down Pipe.
Yea down pipe / jpipe are the same thing .. down pipe is usually the term used for turbo systems. The exhaust resonator is past after the 3rd cat I believe.isnt the downpipe part of the j pipe?
just to clarify even though im repeating what most have said....OOOOooo.......so there are no cats at all?
thanks, i just need more clarifyingjust to clarify even though im repeating what most have said....
there are 3 cats in your accord, the first 2 are before the j-pipe. Pre-cat delete (PCDs) remove these first 2 and are sold separate from the long tube J-pipe. the 3rd cat however is after the OEM j-pipe and the RV6 jpipe is extended (hence the term long tube), thus deleting the 3rd cat. Look on RV6's site or search the original thread if you need additional info...
There are other manufacturers (i.e ATLP) who do standard j-pipe systems that dont delete the 3rd cat and require a test pipe separately if you want it gone.
Just put my RV6 J-pipe on order![]()
What else do you need? Or did he pretty much clear things up for you?thanks, i just need more clarifying
Actually..... the RV6 Jpipe with the cat delete mellows out the sound... Actually it more livable with the Jpipe... there is a lot less drone in the car... I ran about 2 weeks with my car with only cat-back.... It was almost unlivable in the car at 120km/h... now.. I can actually carry a conversation with someone in tha car.. Also since all my mods... I actually run at 7.6 l/100km which comes out to about 31.5 mpg highway!!I heard from my guy say that J-pipe will make really loud sound ? Any one stay in CA got pulled over bcoz of this Jpipe before? I got Megan OE-RS and wanna modify it wif Jpipe.
