Just my thoughts - but if you put a larger throttle body onto any recent design engine that has been tuned for maximized flow efficiency by engineers that do that kind of thing to squeeze 1 or 2 hp more with every effort or small tweak - then changing the flow characteristics in one small segment of that entire flow path will disrupt that maximized efficiency.
You might get a small gain here or there - but you may end up with losses elsewhere that are larger than the insignificant gains you might have made.
In other words - you might not see any gains unless you increase the demands of the engine (i.e. larger ports/valves, performance cams and exhaust.)
Just my .02
