1 - 3 of 3 Posts
New here, but anyways, I'm swapping in a jdm h22 (obd1) into my 91 accord! I have everything down, my only question is the transmission. I'll be using my f's tranny on the h. Will I need to modify anything? Mounts? Or is this just for when you use the h tranny?
Premium Member
i believe you should be okay. most f22 and h22 parts are interchangeable and the transmissions are the same basically. i think you should be good to go.
if your not swapping from auto to 5spd your okay nothing needed. everything is literally bolt on.
1 - 3 of 3 Posts
