I am looking at buying and installing the K&N air intake system in my coupe. To all the intake owners out there, is it worth the $275?...what do you gain/lose?
I personally don't think intakes increase hp gains. I think it is just psychological. The car will sound a lot more aggressive with any intake you go with. I don't think there are any drawbacks to having an intake. The intake will bring colder air into your engine at a faster rate which will increase your air to fuel ratio, which is a good thing. I mean some people say they get better MPG with an intake, some say the car feels more responsive, but I don't have it so I have no idea haha. Others will likely chime in soon. I would say do some search on here first before asking this type of general question... I am sure there are multiple threads about multiple types of intakes.I am looking at buying and installing the K&N air intake system in my coupe. To all the intake owners out there, is it worth the $275?...what do you gain/lose?
While it's possible that a K&N drop in provides for greater flow than a paper filter the question of whether the paper filter is a restriction must be asked. In most cases there is no notable restriction with the paper filter and the engine would in fact make the same power with either a paper filter or no filter at all.Because there are "no gains" with the intake, how about a K&N drop in filter?
Look at it this way, more flow (whatever that means). And you don't have to buy air filters anymore. It should pay for itself in 2 years.
Exactly. I've seen UOA after UOA with elevated silicon when the car has a K&N installed. That doesn't necessarily mean it will shorten your engine life, just saying.While it's possible that a K&N drop in provides for greater flow than a paper filter the question of whether the paper filter is a restriction must be asked. In most cases there is no notable restriction with the paper filter and the engine would in fact make the same power with either a paper filter or no filter at all.
Then there's the filtering capability of the K&N. In my experience, and has been documented on the internet, a K&N just doesn't filter as well as a paper filter.
And then, should you accidentally over-oil the K&N you stand a good chance of coating your MAF with oil. The one possible (but unlikely) benefit of a K&N, increased air flow, just isn't worth taking the risk of coated MAF and less filtration.Exactly. I've seen UOA after UOA with elevated silicon when the car has a K&N installed. That doesn't necessarily mean it will shorten your engine life, just saying.
I run K&N drop-ins on both my Accord and Odyssey. I know a guy with a 94 Integra with 297K miles on the clock and still runs like a champ with K&N Cone filter. And even guys in (dry dusty) Arizona that use K&N for decades, and never had an airfilter related problem.That seems to be the issue I've heard about is possible damage to the MAF because of the oiled filter. However, I have an oiled drop in K&N Filter in my08 Odyssey and have not had any issues in the 3 years it's been in the van. If you're concerned about the oil, you may want to go with a dry filter if you decide on the CAI.
