Can I swap a k24a4 intake manifold with my k24a8 because the a4 has a throttle body spacer upgrade where as the a8 does not if anyone knows i would like to hear your thoughts
Gotcha. I'll be adding a IMG gasket on the injector to manifold side as well as injector to block side. Dual gaskets FTWNo, as long as you reconnect all the vac lines. Make sure you swap the TB manifold gasket to prevent air leaks.
