1 - 20 of 61 Posts
8thsedan
Los Angeles
my friend keeps saying that his 7th gen accord engine is way better than mine when he doesnt even have an intake. which is a better engine? the 7th or 8th? you guys all know the specs. oh and which i-vtec does the 8th gen have? the economic or performance?
K24A4
* Found in:
o 2003-2005 Honda Accord, 2003-2006 Honda Element
+ Displacement: 2,354 cc (143.6 cu in)
+ Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
+ Compression: 9.7:1
+ Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
+ Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
+ Redline: 6800 rpm
K24Z3
* Found in:
o 2008 Honda Accord LX-S/EX/EX-L trim models
+ Compression: 10.5:1
+ Power: 190 @ 7000 rpm
+ Torque: 162 ft·lbf @ 4400 rpm
+ Redline: 7100 rpm
your friend is probably jealous of what you got :thmsup:
K24A4
* Found in:
+ Redline: 6800 rpm
K24Z3
* Found in:
+ Redline: 7100 rpm
+1, if you're just looking at the engine and disregarding potential weight differences, tranny differences, etc., just look at the engine specs.
Your friend can eat it.
How does he like them apples.
As far as economic/performance i-vtec in the accords, it's more economic. Our engines only get VTEC on the intake cam vs. the Civic SI/Acura RSX/TSX K-series have vtec on the exhaust cam as well. You can tell especially when comparing the 190hp/162tq k24 in accord to the 201hp/172tq k24 in 09 tsx. Significant difference from the added valve timing control and im sure it has a slightly more aggressive intake cam profile which id actually like to find out if it can be swapped out for the intake cam in our engines.
But i digress... I do have one question. Do our engines have direct injection? 10.5:1 compression/ratio is high for 87 octane. My H22A4 prelude was 10:1 but used 91+ octane. So what gives if it isn't direct injection? How does Honda prevent detonation?
I have both 7th and 8th gen and the 8th gen engine is definately better. that extra 30hp does help a lot when you need to make a quick turn or change lane
Which car has a more linear power delivery?
Gen7 makes 160 hp @ only 5500rpm
Gen8 makes 190 hp @ lofty 7000rpm
fuel economy: definitely Gen7...
power: definitely Gen8...
The 09 TSX is same mechanical engine as ours except CR 10.5>11.0 and possible slight cam changes (not sure here but cams are not same part # ).
Look at previous TSX with Vtec on both intake and exhaust vs 09 with only on intake. They lost few hp at top end but gained 10 ft/lbs of TQ .
no direct injection on K24 or J35 .
Not according to EPA numbers, don't they both have the same numbers an 08 EPA is a stricter test .
Discussion starter · #19 ·
:thumbsdow
wow so even with almost 200 HP, the i-vtec is only in the intake, w/ only 2 lobes. so the new 09 tsx has a performance type i-vtec? they have the same engine code basically as well as same 7100 redline. so did the new tsx downgrade or they just upped the torque? there's not much information on these new k24 z series..
Not according to EPA numbers, I don't they both the same numbers an 08 EPA is a stricter test .
I thought 7 gen was 166hp? thats what my sticker says
1 - 20 of 61 Posts
