1 - 4 of 4 Posts
I used to be very heavily into car audio years ago, but my last few cars have been leased and I've was content with their Bose or similar systems. Well I purchased a 2.0t sport a few days ago and the system needs to be upgraded asap.
The Kicker Key 180.4 looks like a great way to beef up the sound with out dropping a lot of money right now. My plan would be to start with the amp, then upgrade the front components, somehow add a sub, then upgrade the rear fills for S&Gs.
How does everyone like the Kicker so far? Is there a noticable improvement with the stock speakers? Any opinions are appreciated.
From what I have read the kicker key is a great amp but it will only except a 4 ohm input. Anything lower than four ohms will cause kicker key to cut out or shut off. For that reason alone I went with the alpine powerpack which is the same size and same wattage. There are way too many great speaker options that are not 4 ohm to limit yourself. Now if you went with a set of kicker components and kicker coaxials you wouldn’t have a problem. But the infinity speakers, JBL speakers, and many more or less than 4 ohms. Also make sure you tap the front speakers for the signal input to the amplifier to ensure you have the maximum clean signal to drive the speakers. I used the front speakers for input and drive my coaxials in back and my components upfront, sure you lose the fader option but I used to gain control on the amp to set the fade as I seen fit.
The Kicker seems to be the only amp in this form factor that includes DSP and from my initial listens it seems the accord can certainly use some time correction. I was planning on using Infinity components in the front, which may complicate things as they are 2.7ohms. How are you liking the power pack?
I may just stick with my original plan and go with a dedicated DSP and a standard 4 channel amp. Decisions, decisions.
I absolutely love the power pack and was concerned with the DSP feature as well. After swapping all the speakers and installing the power pack I was amazed at the sound quality. I have the filter set at 60hz and with Spotify and the EQ in the app I was able to adjust the sound quality perfectly for my liking. I was even looking at the Dayton DSP but after turning my system I really don’t feel like I need it. Sure the timeline would be icing on the cake but I’m not sure it’s worth the headache of turning the DSP.
1 - 4 of 4 Posts
