1 - 20 of 23 Posts
plumcrazebody
Orange Park, FL
ok, so i could not stand the feel of the plastic steering wheel and for $142 through Majestic Honda, I purchased my leather steering wheel here.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgry2=2013&catcgry3=4DR+TOUR+%28V6%29&catcgry4=KA6AT&catcgry5=STEERING+WHEEL+%28SRS%29
I am not responsible for any damage to you and your car. Do at your own risk.
ok, so first thing to remember… do not have the battery connected at any time that you have the airbag out, as it will trip the airbag warning light which the dealer will have to reset.
Step 1: with the car off and key removed from the ignition, turn the wheel until the column locks. You will see why when trying to remove the center bolt holding it on.
Step 2: Now disconnect neg/ground terminal on the battery. (Do not do this until you do step 1 or the column will not lock.)
Step 3: you will need a T30 torx bit. (I've already removed the screws but here is where they were) Remove the torx screws on both sides to free the airbag.
Step 4: The airbag module will be free but you still have 3 plugs to remove.
the black(this one is the horn) on at the top was kind of tricky because the foam rubber was hiding the release button. you'll have to feel for it. it is a small ridge towards the middle of the connector. next, you have the yellow and green ones on the back of the airbag. these were kind of tricky too. you will see the white little "wing" tabs on both sides of each connector. pull up on those at the same time and it should release each plug
You also want to unplug the long white harness from the upper portion that is plugged into the column.
Step 5: carefully place the airbag in a safe place outside the car. i always lay face up just for any freak incident of deployment, it isnt a projectile. as long as you handle it with care you'll be fine.
Step 6: You'll need a breaker bar and a 10MM Hex bit socket. If you dont have one, here is what i bought from home depot.http://www.homedepot.com/p/Husky-3-8-in-Drive-10mm-Hex-Bit-Socket-H3DHBS10MM/202913545#.UfEtKHrFFhA. You'll probably have to put a good bit of @$$ into it; its on there good.
Step 7: Take a picture of the wheel so you know what angle it replace the new one, as there is no master spline to help you line it up. the wheel should be free, just be careful as the airbag wires will fish out of the top opening of the wheel. You also want to be very careful not to pull apart the spool.
Step 8: Once the wheel is out, you are going to transfer everything to your new wheel. You will a silver screw at the top left and right holding the corner of the button trim plates. remove those and now you should be able to unsnap the back cover off of the wheel.
Step 9: there are four more screws on the back side. remove those and keep them seperate from the first two.
Step 10: there is a black screw at the lower left that is holding a bracket connected to the trim piece. there is another black screw on the right side grounding a wire for the horn. remove those
Step 11: everything left inside the wheel should come loose with a little finagling.
Installation reverse of removal.
(i decided to 3M wrap the button trim pieces while they were out.)
Excellent tutorial. Thanks!
I so want to do this, but am still a little nervous about the air bag.
Thanks for the instructions.
Nice job! Was that $142 shipped for the wheel?
Jay
That's nice! :thmsup:
Hey just curious is that carbon fiber on the sides of the main part stock or custom. Looks nice.
Nice work. I have the Sport model and love the feel of the leather steering wheel. I drove a LX model first, then the Sport. There is a big difference in the feel, and the grip is better too.
Ive swapped a 2012 and 2013 civic, my 07 element and this car…just be sure to disconnect the battery and once the airbag is out, handle it with caution.
Jay
there was some cost in shipping… i dont know what it was for just the wheel, as i ordered several items.
its a 3M vinyl wrap. check out this thread. its pretty long but skim through and check out pics everyone has posted. if you have time, read through it. That is where i got my motivation. http://www.driveaccord.net/forums/showthread.php?t=80744
Plum, thanks for the link. Looks great. Good job.
Good job, looks good.
I have a EX-L V6 and a EX-L I4 which both come with leather steering wheels, but the one in the 4 cylinder feels better than the one in the V6. Anyone know if there is a difference or is it just my luck that they feel different.
pulling those airbags makes me nervous too. I wonder what a dealer would charge to swap. 1 hour of labor?
Discussion starter · #14 ·
They are all the same part number. I checked all the way from the sport to the touring.
The catch to a dealer is the fact that they will want to charge you twice the price for the wheel plus labor most likely. Usually they will not use outside parts even if its still genuine Honda
Discussion starter · #16 · (Edited)
I might just switch it one day when my wife won't notice. Lol thanks for the info
its definately been worth it. its one of the nicest feeling buttery smooth leather wheels honda has used. I think the next runner-up was my RSX. oh yeah and it really takes about 30-45 minutes depending how quick you are...
I love the feel of the leather wheel too. One of the reasons that was a decision point for getting my model was the lack of friction between my hands and the plastic wheel on my '98 Accord in the winter. That wheel was darned slippery and I was constantly having to blow on my hands to make them more "stickery". We'll see if this leather wheel solves that problem. I'm not much for wearing gloves while driving.
Discussion starter · #20 ·
Wait, do NOT disconnect the battery when removing the airbag?
definitely disconnect the battery. Don't make the mistake I did and reconnect it before reinstalling and plugging in the airbag or it will trip the airbag light on the dash. I had to have the dealer reset it... which you know dealerships... they think we are idiots and tried to tell me it was because of the carbon fiber garnish i replaced. It was an act of congress just to talk them into resetting it. They finally did and haven't had any issues.
1 - 20 of 23 Posts
