I just bought LED from Superbrightled.com for my map/dome lights, I noticed on their website the same LED could be used for the Park Light. So when they arrived I want to check and see if the brightness on the park light would be enough or should I get a brighter LED.
So last night I first put the LED in the Park light and nothing happened so I flipped the LED around and still nothing so I figured damn must be a bad LED.
So then I went to try it in the Map light and it worked perfectly. Id tried searching to find if someone else had a problem like that but it seems more like the WEBSITE I bought from has the wrong LEDS labeled. Below is the link for the led.
https://www.superbrightleds.com/mor...tower-miniature-wedge-retrofit-car/1728/4112/
