Does the right side do the same thing with the balance set to the center? If not, you may have a defective speaker. Take the car back to the dealer and have them replace the speaker.When I play songs with a lot of bass the left front speaker hums/buzzes/vibrates a bit too much. I don't know if the speaker is doing this or if the door piece in front of it is causing it.
It doesn't. It only happens on high bass songs.Does the right side do the same thing with the balance set to the center? If not, you may have a defective speaker. Take the car back to the dealer and have them replace the speaker.
Since the right side doesn't have the problem with the bass that probably means the speaker on the left is defective. The dealer can replace it under warrantee.It doesn't. It only happens on high bass songs.
Podcast and Bluetooth. Simple.How did you get your stock speaker to play Bass?
Jay
How can I take the door panel off without damaging it. I'm not really good at that kinda stuff......or door panel rattle. Take the door panel off, play a song that you know makes the sound you're hearing & listen.
If it makes the sound: it's the speaker
If it does NOT make the sound: it's the door panel (deaden or return to dealer for them to do)
DONE.
I am using my Bluetooth most the time off of my iPhone 5S. The sound is much better than radio obviously. So it sounds like I have to leave the bass level low.If you have the bass level maxed out, and are playing your music loud, then it is just the limitations of our Honda audio systems, along with you trying to compensate the inherent lack of bass from the tiny magnet speakers. What you are doing is just driving the HU's amp into distortion. And..the radio section really is the weakest part of our Honda audio system.
Try playing music using another source (iphone streaming, Pandora, CD etc)
see if it sounds better.
What are your bass settings?I have a similar issue with my RIGHT side tweeter.
On high bass songs, it'll buzz like a bee. it's annoying as well.
The left side does not do it.
I don't know why the tweeter is buzzing though... unless the front speaker is causing enough vibration to cause something in the tweeter area to buzz....
already done that.Before you start pulling door panels, be sure to check to see if there isn't something in the door pocket vibrating when the music has a lot of bass. I thought I had the same problem on the right side until I found that it was a the junk my wife stores in her door pocket. :lmao:
Definitely running into distortion. 'Most' factory speakers are high-sensitivity, low excursion drivers. They're made to play somewhat loudly off minimal power. They're very cheap drivers first of all, but to add to that, any excursion over a few mm will likely get into distortion quickly.I tested something out. The Bass was set to the highest level at 6. I turned it down to 2 and 3. The buzz is gone. This is horrible because when I play the radio there is no bass at all. I normally use my iPhone 5's Bluetooth to listen to podcasts. Level 2-3 mean ok bass, but not great. Since my front left and right rear speakers have this buzzing at level 6 and none at level 2-3 should I still have the dealer replace them or does everyone else have the same issue?
If it's buzzing it's either blown or you have a rattle.already done that.
i always empty stuff out in those pockets because it annoys me lol
it's definitely a right speaker/tweeter area issue
my bass isn't on the max it's maybe on +3 or +4 i think.
it could be the tweeter trim for me being loose, i may just remove that since it's an easy removal and then attempt to see if anything is loose
I tried this. No buzzing with the bass at center level. This takes the fun away of listening to my podcasts with mainly treble. When the bass is at level 6 and I use my hand to lightly press the trim on the door panel there is no buzzing.Definitely running into distortion. 'Most' factory speakers are high-sensitivity, low excursion drivers. They're made to play somewhat loudly off minimal power. They're very cheap drivers first of all, but to add to that, any excursion over a few mm will likely get into distortion quickly.
Play a song where it does it. Turn the bass ALL THE WAY DOWN after you find the song/part of song where it buzzes. Play the song again and if it doesn't do it it's likely resonance from the mid vibrating the tweeter housing/sail panel. If it's still doing it then it's likely blown. Try it with the car on ACC to remove engine noise/vibration, etc.
