This month (November 2021) I have gotten four lights to come while attempting to start the car:
Malfunction Indicator Lamp
Vehicle Stability Assist (VSA) System Indicator
Electric Power Steering (EPS) System Indicator
Low Tire Pressure/TPMS Indicator
They don't stay on for too long maybe like a day and everything goes back to working again. It has happened 2 times in the last month. Here is the picture of the dash:
Has anyone come across this? Or know of a common issue with this?
They don't stay on for too long maybe like a day and everything goes back to working again. It has happened 2 times in the last month. Here is the picture of the dash: View attachment 535964
The lights showed up when there was a temperature change. Maybe it is a grounding wire corrosion. Is there a place where all these items are grounded in the same place that could cause this?
It is a common issue when the battery is starting to fail; so don't overlook even though it's a new battery. Don't forget to measure the alternator to ensure it provides enough charging voltage.
A few weeks go by and I don't have anything on my dash in terms of lights on or errors being reported.
However, when I do scan the vehicle using ThinkCar tool I cannot clear this FCW/LDW error. It always displays and shows (attached is the image): FCW/LDW (There are 1 issues for Safety and Security system)
U0416-68 VSA Brake Actuator Malfunction
I know I can clear the DTC with this tool because I have done it before and I've also cleared other DTC while this one was on and it just doesn't go away.
Would a scan tool like ones below give me more information on what is exactly wrong with "VSA Brake Actuator Malfunction":
LAUNCH X431 Diagun V Bidirectional Scan Tool All System Diagnostic Tool
-or-
Autel MX808
