About a week ago or two my car started to make this loud noise when cold starting. Which I would describe as a low growling or grinding noise. I'm not sure what is causing this issue but any help with this problem would be greatly appreciated.
Probably a bearing of some sort on an accessory. Won’t safety lecture you sounds like everyone else has that covered lol. Check the power steering as well sometimes pump bearings can sound weird like that, had that happen on a CSX that came into a shop i used to work at. Good luck!
