Happy New Year Everyone!
Per my usual luck, while out taking in the Christmas lights this evening, my oil light came on and began flashing. As I just had a free oil change at the local Firestone store (friend gave me a coupon that was expiring & he was not gonna use), I assumed they'd screwed something up with either the amount of oil, the oil pan plug or the filter.
I immediately pulled over under the closest street light, in order to see if there was anything obvious causing the problem and to check the oil level on the dipstick, and found oil level was okay. I had my flashlight and looked under the car but did not see anything dripping or such. While I was pondering what to do next, a kindly gentleman & his son, stopped to offer assistance. After indicating he happened to be a mechanic and many questions later, he suggested I drive the car home (about 5 miles), said it would be okay and to contact the Firestone store tomorrow if they were open and explain the problem to them. (I can't honestly say that I want them touching the car if they did cause this problem but my mechanic is closed till Monday and I am sure will be busy as all heck come Monday morning.)
I read the owner's book when I got home and it did state not to drive the car when that light comes on but it did not indicate if a flashing light versus a solid one makes a difference. :dunno:
Firestone's oil change consisted of 4.5 qts of 5W-30 Kendall Synthetic Blend Oil and a filter (not sure of the filter name) I have never used synthetic blend oil before and usually have used 10W-30 or 40 dino oil so I am wondering if this change could have caused the low pressure. The mechanic did not say that the car was leaking oil or anything so I am wondering what could have caused this unhappy "concidence."
aranoid:
My 94 Accord Ex has 155,500 miles on it if that gives any hint as to the problem.
As I still have not found any work, I sure hope this is not gonna be an expensive problem. If anyone can advise me as to what I can check or what to have checked and an idea of the cost to expect I would very much appreciate it. Thank you all very much for any assistance you can provide.
PS I tried to research this forum for the low pressure oil light warning but did not find any threads referring to a problem after an oil change...did see it could be a collapsed oil filter, or a bad oil sending unit? so still would be grateful for any other suggestions/directions, etc. Thanks.
